Sat Nav problem
Old Sep 21, 2011 | 09:27 AM
lordjagman's Avatar
Default Sat Nav problem
I have an XJ6 (2007) soverign spec. My problem is that when i set the sat nav and it is either completely wrong or i decide to go somewhere else i can not just cancel it.
Gentlemen (and ladies) can anyone explain how i can cancel a route without having to turn off the ignition switch and wait for 5mins???
LordJagman
Old Sep 21, 2011 | 01:43 PM
Jerry S's Avatar
I've never heard of the Nav self-cancelling by turning the ignition off if you've pressed START on the system. If you've started the guidance, you should be able to select cancel in the route options screen if I recall my 2006 S-Type system correctly (I think the 2006 and 07 XJs used the same Nav system.) If you haven't started the guidance, you should be able to back out of all your selections using the back arrow on the destination screen
Old Sep 22, 2011 | 08:16 AM
lordjagman's Avatar
Jerry
Thank you for your post.
When i cancel all that happens is that i go back through the pages until i get to the Map page which will not cancel, as a result the sexy woman keeps talking to me, in a very scolding voice, telling me to do a uturn.
i will try again .
Lordjagman
Old Sep 22, 2011 | 11:34 AM
Jerry S's Avatar
Instead of the XF forum, you might try posting this problem on the XJ 2003-2007 Forum on this site to see if someone there can help you with this problem. If the cancel option is not working, the Nav system may have a problem.
Old Sep 23, 2011 | 09:23 AM
lordjagman's Avatar
thank you, i shall do that.
Lordjagman
flyrr100
Sep 8, 2015 10:40 AM
Mike Green
Sep 7, 2015 12:39 AM
pegasus3710
Sep 5, 2015 09:40 AM
martybmw
Sep 4, 2015 11:05 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
