Sat Nav update is stuck at 'Updating map data... 50%
Old Apr 25, 2017 | 08:00 AM
Creaven's Avatar
Default Sat Nav update is stuck at 'Updating map data... 50%
Hello
Having bought a genuine Here USB map, the SAt Nav update is stuck at 'Updating map data... 50%' cant seem to find a solution at Here or Jaguar, any help would be much appreciated please.
_______
2012 XF (added by GGG)
Old Apr 25, 2017 | 09:44 AM
Welcome to the forum holiday,
I've moved your question from General Tech Help to X250 forum. Members here with the same model will be able to help.
Old Apr 27, 2017 | 11:24 AM
tonyliff's Avatar
Did mine a couple of weeks ago in 1/2 hour stages with my engine running. I found that each 5% takes about 7 or 8 mins to complete. I also had a couple of hiccups while installing. Firstly an error message came up saying it couldn't continue the install and to re-insert disc even though like you I was installing via a usb stick. I turned off the engine removed and re-inserted the USB stick, started up again and it carried on from where it had stopped. The second problem was another message saying I was trying to install an older version, which I obviously wasn't. This time there was a cancel button to press and it again carried on installing. You would think with all the tech installed in these cars there would be an easier way to do this upgrade. If you haven't already done so I would pull out the USB stick, re-insert it, wait for about 10 mins and see if it continues. Hope this helps.
newxfdriver
XF (X260)
Jul 4, 2017 03:28 PM
FrickenJag
Mar 12, 2017 09:32 PM
TexMurphy
Feb 18, 2017 04:18 PM
Don B
General Tech Help
Nov 9, 2015 12:59 PM
