Screenwash not working
Old Jun 26, 2023 | 04:20 AM
padds10's Avatar
Default Screenwash not working
Hello All.
Some help please on my 2010 XF 3.0 D.
My screenwash pump is not working.
I have replaced the pump but nothing, so checked to see if the pump was receiving power and it was not when engaging the switch on the stalk.
I have checked the fuse and that is ok.
Would the next step by to change the relay? What number relay would that be as i can't find reference to a diagram online.
Could it be the stalk switch that's failing? The wipers are ok.
Any help is appreciated.
James
Old Jun 28, 2023 | 08:37 AM
fivel's Avatar
Originally Posted by padds10
Hello All.
James
Do you have headlight washers? From the wiring diagram it looks like the screen washer doesn't have a relay whereas the "power wash" option does. If you press and hold the wash button do the wipers move? That will tell you whether the stalk is working as the IPC sends the appropriate wash and wipe commands on the MS CAN. If its doing the wipe when you press the button then the stalk is working and it seems you are looking at an electrical issue between the junction box and the pump (or the power wash relay), if there is no wipe then its probably the stalk.
Old Jun 28, 2023 | 10:33 AM
Originally Posted by fivel
..... From the wiring diagram .....
Great reply.
Old Jun 28, 2023 | 11:26 PM
Gator8's Avatar
Mine recently failed; the headlamp washer works but the screen does not. The wiper cycle does work. I had the same issue with my 2011 XK—it has two pumps, one for the screen and one for the lamps. I replaced the screen pump and that fixed the problem. I’m going to try the same on my XFR. Aftermarket pumps are inexpensive and will fit.
MJS3
General Tech Help
Jan 18, 2023 07:46 AM
AlexJag
Oct 13, 2021 02:41 PM
Doug Dooren
Mar 18, 2018 03:20 PM
aconley
Apr 10, 2017 12:40 PM
rocklandjag
Feb 24, 2014 09:39 AM
