Seat removal precautions?
Old Oct 28, 2025 | 06:45 PM
Jagboi64's Avatar
Default Seat removal precautions?
I need to remove my drivers seat to take it to an upholsterer to repair a tear in the leather. Are there any precautions I need to observe? Disconnect the battery before I start? I don't want the airbag going off.
Car is a 2013 XF, Canadian market with heated and cooled seats.
Old Oct 29, 2025 | 02:07 AM
POD XF's Avatar
I don't think you can set off the airbag without doing something really stupid. You need power to the seat to be able to undo the bolts, you need to move it all the way forward to get to the back bolts and all the way back to get to the front ones. Also easier to get to the back ones if you lean the upright part of the seat all the way forward, but then you'll probably want to put it in the normal position for the upholsterer. I've taken mine out a couple of times and it's easiest to disconnect the wiring last thing.
Old Oct 29, 2025 | 10:37 AM
DeviLSh's Avatar
^^ This, You need power to adjust it and access bolts/fold the seat to remove easier. Just dont crush the pigtails on accident, or generate too much static electricity and arc the connectors you should be fine.
Old Oct 29, 2025 | 11:05 PM
Jagboi64's Avatar
Seat came out without any difficulty, thanks for the tips!
Old Nov 6, 2025 | 02:13 PM
dennis black's Avatar
Do not remove battery terminals
unbolt and unplug thats it
Old Nov 8, 2025 | 01:41 PM
clubairth1's Avatar
Community Influencer
My only suggestion is to use two people when taking it in and out of the car. Those seat rails can do a lot of interior damage.
I tape towels down over the door sills too.
Spikepaga
Feb 17, 2025 12:09 PM
Pixelated
Aug 7, 2023 12:34 PM
JayCee
Mar 30, 2017 07:38 PM
AL NZ
Mar 29, 2015 04:12 AM
jonbugh
Jul 16, 2009 06:23 AM
