Service light on the 15 XF won't go out
Old Jan 13, 2022 | 02:54 PM
TreVoRTasmin's Avatar
Default Service light on the 15 XF won't go out
Granted I've never had to reset the damn thing on the 15 since Jaguar has the dumbest light ever (only works on mileage and have changed the fluid 3 times since it was last done at the dealer 3.5 years ago as I don't drive all that much) but the procedure that always worked on our old 13 doesn't seem to do anything except waste your time on the 15. Is there a different procedure? Have tried starting with the ignition on then shut it off before the fog lamp button and with the fog lamp button pushed with the system starting cold. Now 25 minues of trying to reset the damn light when the oil change took at best half that. Thanks. I would think my autoenginuity is too old for the xf right?
Old Jan 13, 2022 | 03:46 PM
IanXF's Avatar
Its all a matter of timing and it will work fog light ignition works well
hope this works
Old Jan 13, 2022 | 08:28 PM
BritCars's Avatar
It works on time and mileage. Should indicate one year or whatever the oil change mileage is on your model. Mine comes on at the one year mark every year, and I do way less than the 10-12k my 2010 is scheduled for
You can also easily reset it with a code reader. If you're doing your own diy to the car it's worth getting one. The iCarSoft LRII works well and has a whole host of Jag and LR specific activities too (reset service indicator, put rear brakes into service mode etc)
JDog
Dec 30, 2021 08:28 PM
enacheorlando1
Feb 25, 2019 03:27 AM
TMack
Sep 9, 2014 04:22 PM
licknstick
Oct 6, 2012 12:41 PM
beauregard
Dec 19, 2010 04:44 PM
