Shuddering
Old Jan 20, 2018 | 06:39 PM
smgdata's Avatar
Default Shuddering
For a while now there has been a slight shudder when I brake.
It’s getting really bad as of today.
I don’t know if it’s coming from the front or the rear.
At around 65-85mph, if I start to brake i get this sound, hard to explain on here.
The wheel does not shake but today, There is a bit of a shake now.
It’s a loud juttering sound with Alittle wheel shake.
I’m thinkng now the front right wheel.
Any idea? I was thinking some front end suspension bush is bad?
I’m alittle but nervous to drive it now.
Old Jan 20, 2018 | 07:02 PM
OzXFR's Avatar
The first two culprits to check for are pad deposition (usually incorrectly described as "warped discs") and a stuck caliper slide pin.
Both are relatively common on the XF.
You would need to take the car to a brake specialist to check for pad deposition, and they could easily check for a stuck caliper slide pin at the same time, or if you are even slightly handy with the spanners you can check the slide pin(s) yourself.
Old Jan 21, 2018 | 11:57 PM
smgdata's Avatar
here a video I took of that sound, a few minutes ago. you need to have a good set up speakers to really hear it. its bassy
srteague
Oct 28, 2012 09:48 AM
amcdonal86
May 30, 2011 08:15 AM
Matt
Mar 4, 2011 08:51 AM
msobug
Jul 24, 2009 10:14 PM
