slowly leaking coolent
Old Nov 27, 2019 | 04:25 PM
Fearcedragon01's Avatar
Default slowly leaking coolent
i have a 2014 jaguar xf 2.0t and was woundering if my car has coolent lines that run under the intake manifold. i have checked all the hoses up front and checked the resevoir and everything is good.
Old Nov 27, 2019 | 05:18 PM
StuG's Avatar
A pressure test is the easiest way to pinpointing a coolant leak.
Old Nov 27, 2019 | 05:39 PM
that's what I'm probably going to do. It's crazy cause I just did a flush Saturday. And monday morning it was low with no sighn of leaking anywhere engine temp is fine and no smoke out exhaust or smell the hard part is it's like all owners have the v6. Or via but not the 2.0t. So there almost no information out there for it
Old Nov 27, 2019 | 05:42 PM
[QUOTE=Fearcedragon01;2160126]that's what I'm probably going to do. It's crazy cause I just did a flush Saturday. And monday morning it was low with no sighn of leaking anywhere engine temp is fine and no smoke out the exhaust or smell the hard part is it's like all owners have the v6. Or v8 but not the 2.0t. So there almost no information out there for it
Old Nov 30, 2019 | 12:56 AM
EXEF's Avatar
Did you purge the air out? Probably just a few air pockets in the system after your flushing exercise. Keep an eye on it over the next few days and if the level doesn't drop further, you're home and hosed.
Old Dec 1, 2019 | 01:37 PM
Yes I made sure to purge the air out. Did a pressure test yesterday held 7 psi for a little bit and still nothing. Topped it off drove it about 60 miles to family came out next morning and it was just above second cold fill line on reservoir next thing I'm going to check oil cooler lines
Tonyqt
Jan 20, 2022 08:35 PM
firenfix
Mar 9, 2014 07:34 PM
johnny screwdriver
Jan 19, 2012 03:07 AM
mycaptainchris
Dec 31, 2011 07:26 PM
badmojo
20
Aug 7, 2007 01:40 PM
