Sprinkler
Old May 18, 2020 | 02:48 AM
Sprinkler's Avatar
Default Sprinkler
XK imported from Japan. The reversing camera doesn't work. Would this be because it is imported and has different spec's?
Last edited by Sprinkler; May 18, 2020 at 02:50 AM. Reason: Just trying to sort out the post system
Old May 18, 2020 | 03:00 AM
OzXFR's Avatar
The different spec (if any) should not effect the reversing camera operation at all.
The most likely culprit is a broken wire or two in the boot loom, very common on older XFs and fairly easy to fix or replace.
Also it would help if you added to you signature if your car is petrol or diesel, as both are/were 3.0 V6 and it makes a massive difference when it comes to solving engine related problems.
Old May 18, 2020 | 03:35 AM
Sprinkler's Avatar
Thanks for the info OzXFR. I will look into that.
I have updated me signature.
Old May 27, 2020 | 08:03 PM
Jssaab's Avatar
Does it say reversing camera not operable contact dealer ?
Also, check the sensors, of one goes the system fails. The wire harnesses under the bumper that connects them is very fine and can break when rubbing against the plastic clips that hold it into place
Old May 27, 2020 | 08:08 PM
Sprinkler's Avatar
Thanks for that Jssaab. Sounds like a auto sparky job to me. Not to good on technical things.
crebri
Sep 9, 2019 02:31 PM
Stuart S
Dec 19, 2018 07:15 PM
masalowe
Aug 1, 2017 11:01 AM
kblaw
Mar 22, 2013 04:00 PM
