Start up problems/ p0087 code/
Old Mar 7, 2019 | 11:16 AM
John.j's Avatar
Default Start up problems/ p0087 code/
Hi there.
does anyone had similar problem?
ive jag xf 2.2 2012. From.some time car wont start after a couple of hours of non driving. Even at morning trying to start up the engine and no luck. Car wont start. Sometimes even battery goes flat then have to use jump leads. Then after several turns car starts up. After even 5mins when engine is running im switching off the engine next im starting the engine witch no problems in one go. Sometimes on the way im getting fault on the dash system engine fault. So i brought the car to mechanic. Diagnose was p0087 fault. So mechanic first changed the fuel filter. No luck. Then fuel tank pump. No luck. Then fuel pressure valve and same no luck. So then said the last thing is the high pressure fuel pump. Replaced yeaterday with no luck. Car wont start after a couple of hours of non driving. Any ideas? Thank you
Johncy2000
Jul 18, 2024 06:35 PM
VictorLEE
Jun 18, 2019 05:12 PM
Tango Nevada
Jul 3, 2017 09:11 PM
VictorLEE
Apr 11, 2016 12:34 AM
jacobzking
Feb 5, 2016 07:58 AM
