Startup does not default to previous Audio / Ventilation Settings
Just got my XF back from the service dealership to discover another problem. When starting the car the audio screen shows "No Audio" and the ventellation vents are not activated (closed).
I have to manually hit the audio settings to activate the radio and manually push the vents to open on.
Also my Bluetooth does not connect automatic and have to connect manually.
This happened this morning after startup and when I got back to my car after work when I startup. (Long periods of time when the car is off).
Quick shutdown and startup the memory retains and the system acts normally.
Any idea what I need to do before going back to the dealership?
Regards,
HH
Regards,
HH
