SV8 Persistent Codes P0171 & P0174
Old Mar 26, 2021 | 04:59 AM
fivel's Avatar
Originally Posted by litteredwithfaults
AJ811355
yes, that is the crankcase breather hose I linked too earlier but I wasn't sure if that was the part @gumby7734 was looking for.
Old Mar 29, 2021 | 03:12 PM
Roverlen2's Avatar
Had the same problem on 2006 Landrover LR3 SE. It is a vacuum leak somewhere on the engine. In my case it was the gasket on the Brake booster at firewall.
Plenty of YouTube videos on how to search for it using either smoke blown into intake using a cigar or when engine is running, spray a bit of propane around various vacuum connections. Hope this helps.
Old Apr 28, 2021 | 07:29 AM
gumby7734's Avatar
Replaced Supercharger outlet pipes as per old Tsb. Now long term trim on both banks down to 8. Still too high but at least no check engine anymore. Will keep looking. only breather left to replace.
Affy
Mar 17, 2022 10:13 AM
Autobahn kid
Jan 2, 2022 06:02 AM
razorboy
Feb 7, 2017 03:34 PM
times2fxp
Mar 15, 2015 09:16 AM
times2fxp
Mar 14, 2015 03:09 PM
