Is there anyway of testing if the DPF regeneration is still working on a 2015 X250 XF
Is there anyway of testing if the DPF regeneration is still working on a 2015 X250 XFS?
I've just had a new battery fitted and before and after fitting the battery, the mechanic plugged in an Autel scanner and the only fault code that came up was PO52F, a permanent fault with the Glow Plug Module System. He tested all the glow plugs and all were fine so he thinks that fitting a new Glow Plug Module will cure this fault.
There are no warning lights on the car and it drives 100% fine but if the Glow Plug Module isn't working, DPF regenerations won't take place - I haven't noticed a DPF regen for a few weeks. Is there anyway of testing if the DPF regeneration is still working? Even if I take the car on a long run, it may not regen the DPF as it's not as though it happens on every long run. Thanks in advance.
x2008type
May 23, 2025 11:10 AM
raggeew
Nov 19, 2020 10:21 AM
muskox3437
Jul 26, 2017 12:47 PM
mistyfly
Feb 17, 2014 05:43 PM
