Is there a special code to reset the key fob
Old Apr 14, 2018 | 07:27 AM
Headofbosses's Avatar
Default Is there a special code to reset the key fob
I have a question, I put a new battery in my key fob now I can't get my 2009 Jaguar XF to do a thing
Old Apr 14, 2018 | 10:24 AM
User 42324's Avatar
Apart from checking the battery's the right way up, have a look that the contacts are all correct. When I changed the battery the first time, my key didn't then work. It turned out I'd bent a contact to the battery, (very easy to do), and bending it very gently back into place solved the problem.
Old Apr 14, 2018 | 06:41 PM
BritCars's Avatar
If you can get into the car try docking it into the slot under the steering wheel
Rahul Satoskar
Apr 16, 2018 09:30 AM
