Tire Pressure Monitoring System fault - Remove fuse?
Old 03-14-2017, 07:09 AM
Fairlane500's Avatar
Default Tire Pressure Monitoring System fault - Remove fuse?
I installed 4 new sensors that were supposed to be OEM, but I am still getting the TPMS fault. What would happen if I removed the TPMS fuse? It's F33 in the luggage compartment and according to the manual, only operates the TPMS.
Thanks.
Old 03-14-2017, 06:21 PM
mghirsch's Avatar
How long has it been? The TPMS self resets though it could take over 50 miles.
Phil Aterley (11-23-2021)
Old 03-15-2017, 03:06 PM
It's been well over a month and there have been several trips that would have been enough for the recommended reset process. I have not however, made any trips of 50 miles or more in a single trip.
Old 03-15-2017, 07:52 PM
JBzXJ40's Avatar
Did you have the codes checked? Where did you get the sensors from? Also, I believe there is a number on the sensor that needs to be put into the SDD when calibrating and programming.
Old 03-16-2017, 05:42 AM
My understanding from my Indy is that there are no codes showing. And I also understand that the proper procedure was followed when they were installed. I got the sensors from eBay and the seller indicated they were OEM. I realize I took a chance not getting them from the Dealer, but it was $225 vs. $750
Old 03-16-2017, 10:13 AM
Cherry_560sel's Avatar
have you pushed the reset red triangle button?
Old 03-16-2017, 04:42 PM
JBzXJ40's Avatar
When you get the warning on the dash, what does it say? On the car silhouette, does it show all 4 wheels to be a fault?
Old 03-16-2017, 05:38 PM
take a picture of the warning in your display and let us see what it shows...that will help guide you to the right solution.
Old 03-16-2017, 09:59 PM
09XFwhippin's Avatar
Check your initiators behind the bumpers. Someone before me had one clip in backwards. If you remove the air deflector (plastic covering under the car) there is one on each side at the front. You can loosen the cover just enough to get to it, that's if you don't want to take off the air deflector to fully access the initiators.
Fairlane500 (03-17-2017)
Old 03-17-2017, 05:37 AM
Yes, every time I start the car. It returns each time I restart.
Old 03-17-2017, 05:43 AM
No, it's not that warning. There is no silhouette. It just says "Tire Pressure System Fault" with a yellow triangle.
Old 03-17-2017, 05:50 AM
It says "Tire Pressure System Fault" with a yellow triangle. When I purchased the car, the owner had just installed 4 new rims and winter tires. He hadn't taken the sensors from the summer wheels. That was the warning I was getting then. After installing the new sensors, the same warning remained. I had thought about taking the sensors from the summer wheels, but since they were already 6 years old, I was advised that they might not be working properly anyway.
No one has really answered my initial question - What happens if I just remove the fuse? I'm wondering if the system would recognize a fault in the system if the system had no power going to it. I suspect it can't be that simple but it was worth a try.
Thanks everyone for your feedback.
Old 03-18-2017, 11:32 AM
Removing the fuse wont do anything. The system will still trigger the warning on your dash. Send those TPMS sensors back and get the Jag OEM's. I also have switched wheels. My 20" Sentas are sitting in the garage with the sensors, and the 19" Volutions are on the car without sensors. I just live with having to disable the warning every time I start the car. There is a way to disable the system completely, but you have to have the SDD software to do it. But you already know that.
Fairlane500 (03-20-2017)
Old 03-18-2017, 06:20 PM
BritCars's Avatar
Who is reading the codes for you - an indy or a jag dealer? There should be a code for the fault - but you need a jag specific reader to access it I suspect
Any tyre shop should have a wand that can check the sensors are transmitting without having to take the wheels off the car. Takes 2 mins. Check that they are operational and transmitting.
Old 03-19-2017, 03:58 PM
JBzXJ40's Avatar
I agree, removing the fuse wont do anything. These cars have networks on them, and if a module goes missing, or the fuse is gone, the car will know. Im not sure about Canada, but in the US, at least where I was, that's a safety item, and if you get caught disabling it, could mean big trouble. If you're tire goes flat, or is starting to, then you're not going to know it, hence why its there to protect you and others.
IMO I would get the codes checked to see whats causing the fault.
Old 04-06-2017, 11:24 AM
Cat2's Avatar
Just sent a new post this morning on my TPMS system fault light. How do you disable the TPMS warning light?
Thanks Cat2
Old 04-07-2017, 11:25 PM
Drcummins's Avatar
This might be a dumb question but is there any chance the ones you bought work at a different frequency? I think jags are 315 MHz.
Old 04-08-2017, 10:48 AM
BritCars's Avatar
It's actually a great question. And they vary by region. XF has 315MHz in the US but is I believe 433MHz in the U.K. I notice that the OP is in Canada. So definitely a possibility of confusion. What frequency did you install? And do you know for certain what the right one is in Canada spec cars? (Assuming yours isn't a US export)
Old 04-08-2017, 11:38 AM
carzaddict's Avatar
Canadian spec cars are 315 I believe. my car is canadian spec (i live in the US) and just replaced it with a 315
Old 04-12-2017, 09:02 AM
Interesting. Did they work? I was told by both my Indy and the Jag dealership that mine were 433MHz (Canadian car)
Quick Reply: Tire Pressure Monitoring System fault - Remove fuse?
