Tire pressure monitors - tires losing pressure
Old Aug 25, 2015 | 07:41 AM
rlembach's Avatar
Default Tire pressure monitors - tires losing pressure
I have a 2012 xf. Recently the check tire pressure warning has been coming on and each time I have had to add about 2 pounds to each tire to bring them up to 36 pounds. It seems odd that all of the tires would be losing pressure at the same time. I know that on some other current car makes, when you get new tires they service the tpm's by replacing the valve stems. Can the jaguar tpm's be serviced? Do you think that is the problem?
Old Aug 25, 2015 | 08:16 AM
DPK's Avatar
DPK
How often are you having to air up?..if it is frequent then go have your tires remounted...When you replace tires, as a general rule, they put in new TPM x-mitter units in each tire as they have batteries and get weak after time...IMO a MY12 tire x-mitters should be good for at least 5 years.
Old Aug 25, 2015 | 12:35 PM
tbird6's Avatar
Hard to say but tires do lose about 1 psi air pressure per month.
Was it several months between adding air?
Old Aug 25, 2015 | 12:45 PM
rlembach's Avatar
No, I would say that it was about 2 weeks. And all 4 tires needed air. I could possibly see it if it was winter when tires tens to lose more pressure, but the temperatures have been 80 to 90 degrees.
H20boy
Dec 24, 2024 03:23 PM
smith356
Oct 7, 2015 06:41 PM
johndahlheimer
Sep 16, 2015 05:44 PM
Armor6
Sep 14, 2015 07:56 PM
Armor6
Sep 10, 2015 12:08 PM
