TPMS aftermarket (for Android)
Old Mar 27, 2021 | 02:10 PM
Hunnenkoenig's Avatar
Default TPMS aftermarket (for Android)
I want to buy internal TPMS sensors which work with Android Apps, but I don't want to buy crap.
Does anybody know if there are aftermarket solutions in high quality beside the chinese ones?
Old Mar 27, 2021 | 05:41 PM
Sean W's Avatar
The unit you bought requires a receiver that plugs into one of the USB posts. You should consider buying it. It uses sensors 433mhz so you can use yours. I have an APK for it but so will the seller I would think.
I bought this one from my vendor
https://www.aliexpress.com/item/4000...37144c4djqaECm
Old Mar 27, 2021 | 06:47 PM
Actually I bought one too from my seller, but he didn't give me an app and didn't tell me which one I should download from the Play Store and all apps I tried didn't work.
Maybe my USB connection is faulty, I don't know. I don't know how universal those apps should be.
Anyway, the TPMS I bought, has external sensors and I am not sure if it is a good idea to have that extra weight on the wheels and mainly on the vents.
Now that I have read up a bit on these sensors i realized that I want to buy internal sensors for my summer tires and I would use the external ones for the winter tires and maybe I would later change them too, but first I would need to get them work.
Can you upload your app? Maybe I can use it.
Does yours show the right values?
I bought this one, but it doesn't look at all like in the pictures: https://www.aliexpress.com/item/4001136476685.html
Old Mar 27, 2021 | 08:22 PM
Sean W's Avatar
Check your email and/or PM
Yes, actually my vendor sent me the externals too but by mistake. They have since sent the internals and I haven't installed the but there just standard European 433mhz. The values are correct and I just set an alarm for low pressure but the software also give tire temp and battery voltage.
Old Mar 28, 2021 | 01:21 AM
Got it, thank you!
Old Mar 28, 2021 | 12:30 PM
The app worked immediately. I didn't even have to pair the sensors.
Thank you!
Nick Ward
Dec 29, 2020 10:35 AM
mrNewt
Apr 27, 2019 03:07 PM
tiger_reddy
Jul 22, 2018 02:23 AM
jfranks
Mar 13, 2017 04:51 PM
ilwill77
Mar 3, 2013 07:46 AM
