TPMS Module - Location on XF
Old Apr 6, 2018 | 12:14 AM
Supercharged Jag's Avatar
Originally Posted by TXFireblade
I see you are sometimes in Houston, what Dealers are you using?
I normally use Momentum in Houston and they're really good, but right now I'm in Lexington, KY and the nearest dealers are in Louisville and Cinncinati.
Old Apr 6, 2018 | 12:16 AM
Originally Posted by BritCars
To do the reflash that sounds about right. And typically has to be a dealer as they have the right software
They aren't all bad - I've been with my jag dealer the last 5 years and had terrific service. If you have choices then vote with your feet and find one that works for you
Good luck.
Honestly, I wish I could choose one, but after one or two visits each dealer starts screwing around. So I just rotate back and forth between the two.
Old Jul 30, 2022 | 11:12 PM
jjmartiny's Avatar
Did anyone discover the location of the TPMS Module? I'm not having much luck finding it.
Thanks!
Old Jul 31, 2022 | 05:36 AM
Robtrt8's Avatar
I found mine under the passenger seat. It’s the one that says Continental. Need to remove the seat and carpet to get at it. I did that chasing a leak that had water on both sides of the floor pan.
flyrr100
Sep 29, 2015 03:47 PM
John Fox
Sep 19, 2015 07:56 PM
Tipptone
Sep 16, 2015 07:39 AM
BruceG
Sep 15, 2015 05:47 AM
tberg
Sep 7, 2015 07:32 AM
