Transmission fluid
Old Feb 19, 2018 | 04:19 PM
Dj5ivestar's Avatar
Default Transmission fluid
is there a method to check the transmission fluid level in the 09 Jaguar XF
Old Feb 19, 2018 | 04:33 PM
nsl1's Avatar
There is no easy way (Thanks, ZF and Jaguar). Only way I can think of is to check the level at the fill plug on the transmission.
I think transmission would need to be at normal operation temp and engine running. Not an easy job due to location of the plug and close proximity to the exhaust. A lift would be recommended/required. Might as well go ahead and change out all the fluid and filter if you going to do all that just to check the level.
Old Feb 20, 2018 | 12:40 PM
Bigg Will's Avatar
The car needs to be up and level, it can be done on jack stands.
https://www.jaguarforums.com/forum/x...-fluid-136746/
Old Feb 20, 2018 | 12:47 PM
NBCat's Avatar
Below is the correct procedure for checking the fluid level in the ZF 6HP26/28 gearbox.
Old Feb 20, 2018 | 02:07 PM
pab's Avatar
pab
Yes, the engine must be running and fully warm, and the exhaust downpipe is only inches away from the fill plug... =:-0
You dreamed of a big star -
He played a mean guitar -
He loved to drive his Jaguar...
So welcome to the machine
Old Feb 20, 2018 | 07:51 PM
Polyesterpig's Avatar
The transmission fluid needs to be between 86f - 95f when checking the level. This is why most shops ask you to leave the car overnight. It is easy to over shoot 95f. It takes forever to cool it back down. If you drive the car to the shop, it will take hours to cool to 86f. I know, I changed mine on a lift by myself.
Old Feb 21, 2018 | 11:43 AM
NBCat's Avatar
One other important point is to always loosen the fill plug before attempting to check the fluid level or drain the gearbox.
If for some reason the fill plug cannot be removed and the gearbox needs fluid, the vehicle must be towed to a shop capable of removing the fill plug.
Old Feb 21, 2018 | 11:48 AM
And it only takes a second to get from 86 t0 95.
I found judicious heating with a propane torch did the trick.
Take care not to set the car on fire!
Old Feb 25, 2018 | 08:45 AM
hiltoncam's Avatar
Mine is an 09 and is due for a transmission oil change. I just asked my Jaguar dealer this past week when they could slot my car in for its oil change (I already have the sump which I bought a year ago - not cheap, because it has the filter built in) and they told me they don't do transmission services!!! WTF???
I'm currently getting hold of Jaguar headoffice to have them send a technician to my city who knows how to do this job since my dealer doesn't have the expertise - very bad of them!
Old Feb 25, 2018 | 09:21 AM
bmcinsd's Avatar
This had me thinking,...I plan on doing some exhaust work (downpipes) and the removal of the OEM downpipes would probably make the transmission job easier or would it? Since the transmission needs to be at 85* temperature?
Old Feb 25, 2018 | 11:02 AM
JagV8's Avatar
Any competent gearbox (auto trans) place can change the oil etc. Cheaper than a Jaguar franchise (some quote for it), probably by a lot.
Old Feb 25, 2018 | 11:52 AM
Have you tried BMW? They use the same box. (as do others)
Dj5ivestar
XF (X260)
Feb 21, 2018 09:49 AM
