transmission slip bettween 3rd and 4th gear
Old Nov 19, 2017 | 10:38 AM
gio71's Avatar
Default transmission slip bettween 3rd and 4th gear
jaguar xf supercharged 2009 when the gear change between the 3rd and 4th gear its sleeps and the fault comes on . if im on D gear . if im on S gear its a bit better if im on S gear with race mode on its almost ok .i can go down from 4th gear to 3rd gear no problem at all, but from 3 to 4 it sleeps
the car have 65000 miles on it or 105000km
Old Jun 28, 2019 | 03:44 PM
Gasin Sanjacinto's Avatar
Default Did you solve the problem?
[QUOTE=gio71;1795565]jaguar xf supercharged 2009 when the gear change between the 3rd and 4th gear its sleeps and the fault comes on . if im on D gear . if im on S gear its a bit better if im on S gear with race mode on its almost ok .i can go down from 4th gear to 3rd gear no problem at all, but from 3 to 4 it sleeps
Hello my name is John I also have the Jaguar XF and it's also doing the same thing between 3rd and 4th gear and so far I have not found no info on it ,any ideas? Please
Old Jun 29, 2019 | 01:50 PM
John Williams's Avatar
First thing I would do is change the fluid & the filter, which means a gearbox sump change. Try & find somebody who can flush the box, as this will ensure all the fluid is replaced.
Demetre Gvaramia
XE ( X760 )
16
Jan 24, 2025 03:34 PM
greenforest56
Sep 29, 2024 11:18 PM
Ahenry014
Feb 6, 2017 07:19 AM
BigCat09
Dec 26, 2016 03:27 PM
bluejaggg
May 2, 2008 10:58 AM
