Turning off The engine but not the audio/climate
Old May 18, 2014 | 03:17 PM
ftjag's Avatar
Default Turning off The engine but not the audio/climate
Hello fellow jag drivers,
I was wondering if there is a way to turn off the engine in a 2013 XF (start/stop button) without turning off the audio/climate?
For me it sounds like I have to turn off the engine which also turns off everything and then turn on the audio/climate.
Thank you
Old May 18, 2014 | 03:34 PM
MrChuckles's Avatar
If you use "eco-mode" when you put the car in park, it will cut the engine and keep the Audio/climate running. Downside is using "eco".
Old May 18, 2014 | 11:29 PM
ftjag's Avatar
Yes, with eco-mode you can do that but the problem is after few seconds, even if you put the car in the park, the engine restarts automatically.
Old May 19, 2014 | 03:31 AM
glenonoka's Avatar
It is the air pulling too many amps. It should stay off for a while if you aren't using the air.
Old May 19, 2014 | 12:54 PM
ftjag's Avatar
You are right. When I turn off the air, the engine stays off longer. That is good but better if I could have both (audio/air)
Old May 19, 2014 | 07:32 PM
MrChuckles's Avatar
It even says that in the manual. If the A/C or Heat is running, depending on the outside temp, inside temp, and fan speed you have selected it may not shut off. and if it does, it wont stay off for long.
JarodL
Mar 7, 2024 01:39 AM
D.K
Dec 10, 2023 02:05 AM
laserguy
Sep 3, 2015 02:02 PM
OkieTim
Sep 2, 2015 12:48 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
