Way to avoid 3min ignition on when using SDD?
Old Aug 10, 2020 | 01:58 PM
pjfox's Avatar
Default Way to avoid 3min ignition on when using SDD?
When using SDD diagnostics, how can one avoid the auto ignition off after 3 mins ?
Old Aug 10, 2020 | 02:23 PM
Brake buster's Avatar
you need to connect the car to a ' power support unit ' to maintain voltage
once the OBD2 is connected, and you follow the laptop instructions in SDD , no need to worry about the ignition position, the laptop will prompt you
BB
Old Aug 11, 2020 | 07:20 AM
sockpuppet's Avatar
I have been meaming to ask this question myself, I had mine connected to a 30amp charger the other week and the car still shut down with SDD running. It wasn't down to low voltage either as the battery measured 12.44v
Old Aug 11, 2020 | 07:39 AM
pjfox's Avatar
Yes that is exactly the problem, I have a 60A charger but it shuts down anyway. Am looking if SDD offers some solution, if so, will post it here....
Old Aug 11, 2020 | 04:42 PM
clubairth1's Avatar
Community Influencer
It's been well documented that you need a stout DC power supply with proper regulation. I had to break down and get one because no battery charger will work.
You need something like this;
I think you need 12.6 VDC minimum or SDD shuts down. My car runs 13.4 VDC with the power supply hooked up.
Box
Oct 5, 2023 07:51 AM
tbaxl
Mar 16, 2020 08:50 AM
sayitaintso
Jan 29, 2018 07:04 PM
melhookv12
General Tech Help
Jan 7, 2017 11:40 AM
barnter
General Tech Help
Apr 5, 2016 01:00 PM
