What size spacers for XFR
Old Jan 25, 2021 | 06:25 PM
Oxidizer2k's Avatar
Default What size wheel spacers for XFR
Looking to get wheel spacers and from what I’ve gathered 25mm in the rear seems appropriate. For the front am I looking for 15 or 20mm? I’ve looked at a few threads but there were non XFRs. Pictures would be helpful. Thank you.
Old Jan 30, 2021 | 09:50 AM
les's Avatar
les
Hi.
I've got 15mm front and 20mm rear on my XFR. The wheels sit just right for my liking and there's no issues at all.
Old Jan 30, 2021 | 09:21 PM
wimmer's Avatar
20 and 15 with stock nevis wheels is perfect. I changed my wheels I have 2 black 20 mm that I would sell to you for $50 shipped pm if interested
Old Jan 30, 2021 | 09:51 PM
Oxidizer2k's Avatar
Thanks for the replies. Pictures really help. Because no one responded to the thread in a day, I ended up ordering 15mm front and 25mm back. Hopefully the 25mm won’t look too bad for the back. I’ll post some pics when I get them installed.
Old Jan 31, 2021 | 06:48 AM
les's Avatar
les
The XFR-S has 10.5" rears as opposed to 9.5" XFR rears, so, 25mm should be OK I think.
Old Jun 2, 2021 | 10:12 PM
rightlane_j's Avatar
Did you ever get them installed? Pics?
Old Jun 3, 2021 | 07:05 PM
Oxidizer2k's Avatar
lol I bought them and they’ve been sitting around waiting to be installed. Have been too busy at work/life. Ill give it a shot next week. Need to get a grinder to cut the front studs off a little bit for the 15mm spacers.
Old Jun 3, 2021 | 07:20 PM
OzXFR's Avatar
Why?
No problems with the stock XFR wheels (such as Nevis) that I am aware of, or do you have non-stock wheels?
For stock F-Type wheels yes all except the Blades need the studs trimmed for 15 mm spacers to fit as the voids in the back of the wheel between the stud holes aren't deep enough for the original studs to clear but I didn't think this was a problem with stock XFR wheels.
Old Jun 3, 2021 | 11:02 PM
Oxidizer2k's Avatar
Originally Posted by OzXFR
Why?
I have stock wheels. there are a couple of videos l watched where 15mm required some of the wheel studs to be cut off. Here’s one:
Old Jun 4, 2021 | 12:14 AM
OzXFR's Avatar
https://youtu.be/aEIEV8ff8WI
I stand corrected!
Yes, the wheels in that vid are Nevis and I had the same on my 2010 XFR.
Where I got mixed up is I put spacers on my old XFS (with the stock 18" Venus wheels) but I replaced those wheels with 20" Coventry Whitley wheels in XFR spec sizes (but different offsets), and then I swapped those wheels over to the XFR, so I never did put spacers on the XFR.
So now we know that Nevis are the same as many/most Jag wheels and can't take 15 mm spacers without trimming the lugs.
Old Jun 5, 2021 | 11:41 AM
Yes I read about having to grind down the studs a bit to fit the 15mm. I ended up ordering 25mm/20mm to avoid that situation and I measured my car and these sizes will be fine. I'll try to post some pics once I receive and installed.
Old Jun 5, 2021 | 10:24 PM
Nansan21's Avatar
I went 20mm allround on mine when the originally planned 15mm spacers for the front would need to grind the studs. The car sits on 20" Dracos.
Old Dec 25, 2022 | 05:30 AM
Adonissz1's Avatar
Default Are those spacer.Still available? I’ll buy them now please.
Old Dec 27, 2022 | 07:01 PM
I have a 2012 XFR on 20 inch stock Dracos and I went with 25mm rear and 20mm front and they look great. I'm also lowered in the front on Eibachs and have no issues with 4 people in the car. **** I think another 5mm all around would be fine as well.
Old Jan 13, 2024 | 05:36 PM
Sancho20's Avatar
Does anyone have the h&r part numbers for the 15mm and 25mm spacers .? Thanks
Old Jan 23, 2024 | 07:02 PM
Jssaab's Avatar
I have a set I will sell.
Old Feb 22, 2024 | 08:17 PM
Stosh1017's Avatar
Default XFR spacers
What size are the spacers for sale
myshao
Jul 4, 2023 01:25 PM
chrisc200
Jan 30, 2021 09:22 PM
Seymour XFR
Mar 11, 2020 07:17 PM
OnlySlightlyEvil
Feb 26, 2019 04:09 PM
damienedwards
Feb 11, 2015 11:43 AM
