Wheel Sizes
Old Sep 9, 2013 | 04:05 PM
spanky145's Avatar
Default Wheel Sizes
Hi Folks,
I just purchased a 2012 CPO XF. This car has 18 inch OEM wheels with tire size 245/45/18 all around.
I am now looking to buy a second set of wheels to use with snow tires. They can either be 18 inch or minus one 17 inch for better snow performance.
After going through E Bay, etc.. I am being told that there are Jaguar wheels from other older Jaguar models in 17 or 18 inch that would fit my car.
Would anyone know where I could get information about which other Jaguar models and year wheels would fit my 2012 XF? I would imagine that there must be some sort of cross referencing guide between models for wheels sizes but I have not been able to locate any. You can write to me on forum or e mail me at eo145@aol.com. Thank you. This would really be a big help.
Ed
Old Sep 14, 2013 | 09:22 PM
matts89xj's Avatar
Find the center bore and bolt pattern of your OE wheels as well as the offset, then for for ones with the same bolt pattern and center bore. As far as offset (et) 1010 tire has a great offset calculator and I generally follow the guide of losing 15mm of inner clearance is acceptable but wouldn't suggest losing over 12mm of outer. Also of you see wheels that have the same bolt pattern but different center bore, you can find hub centric rings to make it work.
Old Sep 15, 2013 | 02:44 PM
spanky145's Avatar
Thanks Matts89XJ. This should be a big help.
Ed
Old Sep 16, 2013 | 08:18 PM
matts89xj's Avatar
I'm happy to help where I can
Forcedair1
Sep 8, 2025 01:57 PM
MrWest
Dec 1, 2015 09:18 PM
Gerard Radimaker
Sep 13, 2015 10:33 AM
metalmarty
Sep 11, 2015 07:05 AM
iownme
Sep 11, 2015 02:57 AM
