winter wheel suggestions for 2010 XF SC
Old Dec 11, 2011 | 07:57 PM
shikk's Avatar
Default winter wheel suggestions for 2010 XF SC
I know this is probably old hat for you guys but I've been trying to search for help on winter wheels (2010 xf supercharged, specifically) but have not been able to find anything conclusive. This guy didn't get an answer in the wheel forum so I thought I'd try here.What is the smallest rim size I can go to get the tallest wheel appropriate for winter tires? I bent a stock enkei rim on my Evo last year and it was heartbreaking (and expensive), I just want cheapo wheels to put good snows on with plenty of padding to get through the snow and pothole season.
I'm thinking 18x8, someone was selling those for an 09 XF SC but am not sure what the clearances are and if I can go smaller. I've seen folks recommend that or even 17's for non-SC versions, but I that sounds too small for brake clearance.
Also, any suggestions/thoughts on cheap rims and recommended tire sizes for said rims would be much appreciated! Thanks in advance.
Old Dec 12, 2011 | 06:10 AM
cwood's Avatar
I had the same question a while ago. Went with 19's because it seemed questionable that 18's would fit. Detroit wheel and tire has OEM's at decent prices (may be reconditioned but what they shipped me looked brand new). I did Blizzak LM-60's. I have had trouble getting the TPMS sensors they included to be picked up by the vehicle.
Old Dec 14, 2011 | 08:54 AM
shikk's Avatar
Thanks for the info cwood, what width wheel and tires did you go with? I'm still looking for a set, thankfully snow is late this year but it's definitely frosting up in the mornings. Anyone else have suggestions/thoughts? Has anyone tried 18" on an XF SC? Thanks all.
Old Dec 14, 2011 | 12:34 PM
cwood's Avatar
I just used the year and model selector to narrow down the choices. I did 8"x19" all around...not stagger. Allows you to rotate front to rear at least.
H20boy
Dec 24, 2024 03:23 PM
D.K
Dec 10, 2023 02:05 AM
hunter34
19
Sep 14, 2022 11:09 PM
PMKimpton
Aug 3, 2019 08:22 PM
08Z06
Oct 24, 2015 05:46 PM
