X250 driver window problems - anti-trap kicking in
Old Oct 15, 2021 | 05:31 AM
Kermie_K's Avatar
Default X250 driver window problems - anti-trap kicking in
Hello all
Long time reader, first time poster! I've got a weird issue with my driver side front window in that when I go to close it the anti-trap feature keeps kicking in and lowering it again. After 3 goes I can then send it all the way up but have to reset the one-shot calibration.
If I inch it up without using the 1 touch it will sometimes go without interruption, and sometimes will go up fine on the 1 touch!
Could it be the door control unit, regulator or wires most likely at fault? Hoping to get the door panel off soon but not sure what I'm looking for. Should I pop some silicone grease on the cables to be on the safe side? Going to sort out a door rattle from the window wires while I'm in there too!
Cheers!
Old Oct 15, 2021 | 06:48 AM
Bigv's Avatar
Probably something jamming it
lubrication of the cables, pulleys and runners is a good idea
Old Nov 7, 2021 | 08:12 AM
UltBlkXF's Avatar
Had same issue
It was regulator
BlueSmudge
Aug 14, 2021 11:17 AM
Woodrun
Sep 18, 2018 10:51 AM
EscapedApe
Mar 19, 2016 01:28 PM
ez53436
Dec 21, 2011 03:11 AM
Lifts
Dec 7, 2009 01:08 PM
