X250 electrical issue
Old Jan 3, 2022 | 08:21 AM
James_1982's Avatar
Default X250 electrical issue
Hi. I have some kind of electrical issue with my Jaguar. At first I thought it was a flat battery, but after charging strange things began to happen (before putting it back in the car battery had almost 12V, I checked it with multimeter). When I connected it to the car, I started to hear a strange clicking noises, lamp in the trunk lit up for a moment and then it goes out. The car is a Jaguar XF 2009 3.0 diesel. Any ideas?
Old Jan 3, 2022 | 10:03 AM
John Williams's Avatar
12v is not enough to run your car, minium of 12.3v.
A fully charged battery should read around 13.2v
Old Jan 4, 2022 | 08:58 PM
BritCars's Avatar
Yes. Your battery is dead. 12v is almost discharged. When the battery is too low on the XF something in the boot/trunk clicks and clicks until the battery is totally dead
Remove and fully charge it for 24+ hours on a good charger. If it doesn't get up to about 12.7V (differs a bit depending on whether it's an AGM or traditional battery - easy to find the tables online to show what you should see for fully charged voltage.
If that doesn't work, you need a new battery.
newbietojag
Jul 22, 2021 11:12 AM
MART
May 8, 2020 03:25 AM
jaguarXFsupercharged_XFR 500HPclone
Mar 7, 2019 10:06 AM
af93
Jan 21, 2017 02:37 PM
katoeh11
Apr 6, 2015 07:19 PM
