XF 2013 - Headlight Washer Jet
Old Aug 5, 2022 | 06:09 AM
Stav's Avatar
Default XF 2013 - Headlight Washer Jet
Straight to the point.
XF 2.2d - 2013
Initially only Left headlight washer jet working. Replaced pump as connectors were corroded with original OEM as a cheap from ebay was worse. Checked wiring, mod was already done and fitted new pump.
Left jet is really powerful and the jet nozzle comes out and sprays immediately and retracts quickly- no problem here.
Right nozzle is slow coming out and sprays one third of the amount and is very slow retracting.
Please see video, that is, if I managed to upload it
Any suggestions / solutions before attempting to replace the nozzle will be appreciated.
MOV_0893.mov
Old Aug 5, 2022 | 06:44 AM
John Williams's Avatar
As the jets are pushed out using water pressure, I assume the pipe to that jet is either squashed or damaged.
Old Aug 5, 2022 | 08:21 AM
Stav's Avatar
More than likely you are right - the part of the pipe that feeds the right jet is squashed somewhere.
I wonder if any has the pipe routing diagram (cannot find it in my workshop manual). That will be of great help.
Old Aug 5, 2022 | 10:45 AM
I think it will require the bumper to be removed?
Old Aug 5, 2022 | 10:18 PM
BritCars's Avatar
Prob the jet. One of mine wore out. They are about $70 each. Get the correct one as left and right are different.
On pre facelift you remove the headlight assembly and the jet is attached to it. Couple of screws to remove and replace. And put back in the headlight
Easy fix
TropicCat
Apr 27, 2021 11:24 AM
JagXK82001
Jan 25, 2020 08:21 AM
NJ.
Apr 10, 2014 10:36 AM
AndersA
May 31, 2013 04:20 AM
Campeon
Oct 21, 2008 06:30 PM
