XF offside main beam comes on when indicating rigt, intermittent fault.
Old Aug 8, 2020 | 05:48 AM
shiraz kid's Avatar
Default XF offside main beam comes on when indicating rigt, intermittent fault.
XF 3.0S 2010. Intermittent fault- offside main beam comes on when indicating right turn, and headlights are switched off.
Old Aug 8, 2020 | 06:07 PM
davetibbs's Avatar
Either you have a ground fault where the indicator is earthing through the main beam bulb, or you have a faulty indicator/light stalk/switch.
Pin 7 to the headlight connector (black wire) should be ground - check you're getting a good ground here with a multimeter, also check general wiring around the headlights. If everything looks good at the headlight end it could be a faulty lighting stalk/switch - these are known to go bad also, but yours does sound like a wiring fault at the lights to me.
Boydy1985
XF (X260)
Apr 18, 2018 04:27 PM
Boydy1985
Apr 18, 2018 04:24 PM
nasa25
Mar 13, 2015 01:26 PM
dubzyb
Jan 20, 2014 02:44 PM
