XF rear window and door lock no functional
Old Oct 4, 2019 | 06:39 PM
Carleden1980's Avatar
Default XF rear window and door lock no functional
Hi All we have a 2009 jaguar xf we have just developed a problem with the rear drivers side window not working and locking system on the same door isn't work as well. Tried the relevant fuses they are all ok . Could anyone enlighten me please m thank you .
Old Oct 6, 2019 | 05:24 AM
XFowner's Avatar
Hi. Your problem sounds like a familiar one. I’ve heard of the rear window problems and seen it first hand on a few XF’s I went to look at when making the purchase of my own.
The door lock is very common and probably the actuator module inside the door which will require replacement. Mine started to drain the battery as the lock circuit was constantly on so watch out for this. Good luck.
Old Oct 6, 2019 | 02:11 PM
Thank you kindly for your reply. Is the window function relevant to the locking part or is that a separate issue . Thanks Carl
hoylegj
Dec 7, 2019 09:04 AM
PJ704
Jun 7, 2019 02:46 PM
Starion
May 7, 2018 11:35 AM
Starion
May 7, 2018 09:47 AM
hoylegj
XF (X260)
Jul 3, 2016 07:25 AM
