XFR misfire on 2, 4, 6 and 8 plus MAF B circuit
Old Jul 21, 2021 | 04:05 PM
elwon20's Avatar
Default XFR misfire on 2, 4, 6 and 8 plus MAF B circuit
Yet more problems with the 09 XFR. If you've followed my previous posts you'll be likely know after 6 months the car has had around 4.5k of repairs. Anywho... Driving along spiritedly, come to a junction try to pull out, no power "thats strange" look down and see DSC light. Unusual I didn't pull out that hard and I've never had tc be that disruptive before!
2 miles down the road: Restricted performance *sigh*
Baby her home, she feels like she's running on 4. Get home do a scan:
P010B - MAF bank B
P0302
P0304
P0306
P0308
(Misfire on cylinder 2, 4, 6 & 8)
Also P0300 and p0316 but I think these are symptoms of the above)
So, I was right, it's running on 4 (intermittently/mostly).
Current plan, is to clear the codes and then start it up again to see if the MAF code is a red herring, which I suspect it may be.
I'm guessing vacuum leak of some sort? Any suggestions/ideas on where to look?
<3
Old Jul 22, 2021 | 01:18 PM
clubairth1's Avatar
Community Influencer
Sounds like that side of the engine has all 4 injectors throwing codes. We have seen several cars do this and usually the dealer replaces all 4 injectors on that side of the engine.
Can you DIY any of the repairs?
Old Jul 23, 2021 | 03:05 AM
elwon20's Avatar
Wow, I'd have thought all 4 injectors on one bank just going at exactly the same time would be really unusual? Unless something else caused them all to die suddenly like that?
I can do a bit, I'm used to servicing my own bikes. But I don't really have the ability to remove the supercharger from this car (I hear it's pretty heavy). So unlikely to attempt anything beneath that myself.
Old Jul 23, 2021 | 10:09 AM
clubairth1's Avatar
Your right and we don't know why but Jaguar recommends changing the entire bank of injectors even when only one goes bad. We have had several forum members change just the one injector with no problems.
As you can imagine 4 DI injectors are not cheap!
SC is not that heavy but it does have 2 locating pins which tend to get seized so you need to pull or pry the SC off the top of the engine.
The plastic cooling pipes are known for leaking so maybe you could combine several repairs at once?
The injectors do take a special tool and slide hammer to remove and they can be difficult to get free.
Old Jul 24, 2021 | 06:12 PM
elwon20's Avatar
Changing all 4 when one goes I sort of see why they're recommending that. But this is all 4 cylinders on one bank suddenly misfiring at once. Which would imply all 4 injectors failed at once. This just doesn't seem likely to me?
I was thinking more along the lines of a broken cat clogging up the exhaust?
The supercharger was only removed a few weeks ago and the coolant pipes under it replaced (along with supercharger oil, coupler and pulley, spark plugs etc). So it shouldn't be too difficult to remove it again but I don't wanna do it unnecessarily!
Old Jul 26, 2021 | 10:32 AM
clubairth1's Avatar
Also think of anything common to all 4 cylinders. Like a ground wire. That has caused all 4 injector errors before too. So other things are possible besides just injector failure.
Was the rear water manifold also changed when the SC was removed? That is another failure prone piece of plastic that is terribly difficult to replace when the SC is on. I would say impossible but at least one person has done it with the SC still on the engine. It's possible but not very easy!
Old Jul 26, 2021 | 10:46 AM
elwon20's Avatar
Yes the plastic water manifold was replaced, all brittle plastics beneath/around that area were.
It's now started misfiring on all 8 cylinders. I'm starting to think this must be a timing issue
It's due to have its gearbox oil replaced at the end of August (after having it fully rebuilt a few months back) so I'm sending it to a garage over near there for them to look at. Hopefully it's not the timing but if it is, I'll just have to sync the cost of the repairs.
It's either that or sell it as is, after having already sunk so much on it. Sunken cost fallacy I know, but I refuse to be that person that buys a dud, spends thousands fixing it and then, after a final straw, sells it on to a new owner who gets to reap the benefits of all those repairs.
Old Jul 27, 2021 | 10:49 AM
clubairth1's Avatar
Yes if it's all 8 cylinders I think you have a wiring or other electrical problem. As you said it makes no sense that 4 or 8 injectors would all go bad at once!
But keep running and erasing the codes to narrow it down.
This is the 5.0L SC engine correct?
In the US we did not get the XFR until 2010 and you have a 2009?
Old Jul 27, 2021 | 11:08 AM
NBCat's Avatar
Check the fuel pressure using the Torque app and a smart phone via the OBD port.
Have the timing chains, guides and tensioners been replaced as part of the 4.5k repair work?
Old Sep 27, 2021 | 07:59 AM
elwon20's Avatar
Update for those who end up here with similar problems and aren't sure what it was. It turned out to be a split fuel injector, peeing fuel everywhere and killing fuel pressure to the other cylinders.
I had all 8 replaced (at great expense).
@NBCat, no they haven't I just can't justify the cost, It's had as much as the car is worth spent on it in maintenance and repairs since January. If it goes I'm screwed, but I bought the car for £12.5k in January, and it's since had over £11k spent on it.
Old Sep 28, 2021 | 08:24 AM
clubairth1's Avatar
Great that you reported back because I have never heard of that failure before and if you could identify the split injector that would be a lot less expensive than replacing all 8 as you had to.
Was gas spraying in the engine compartment or how did you identify the bad injector?
Old Sep 29, 2021 | 06:47 AM
elwon20's Avatar
A jaguar specialist identified it. Yeah it was spraying into the engine bay. I could have just replaced the one but with the labour involved and my intention to keep the car I had him replace all 8, if another had gone in 6-12 months I'd have been rather annoyed at myself for only having the one replaced.
capitalsearch
Mar 1, 2019 04:37 PM
BigMikeATL
Feb 20, 2018 06:56 AM
mhessen6
Feb 15, 2016 11:46 AM
blast20
Aug 3, 2011 10:11 PM
feartheclown
Apr 2, 2011 11:44 PM
