xjr hell
hi im new here ive got a 2000 xjr just brought the car it had sat for about a year. i picked it up serviced it got it running and put it thru a mot first time no problem then after about a day of use the red light on the gear shift started staying on and when it was on nothing would work and a clicking noise from the steering column then the light would go off and all was fine now it is on permanently car is on my drive wont come out of park all 4 windows down i am screwed any one had the same problem or has any ideas hellllpppp
Sorry to hear your problems. Is it an XJR or XFR? You posted on the XF board but said XJ
Many of these cars suffered from an early issue with the rotating gear selector. There was a tsb recall and I'd be very surprised if yours hadn't been done - but easy to call a dealer to pull the records and check. It was mostly 2009 cars I think but could have been some early 2010s too
Other immediate suggestion is to check the battery. Clicking could sound like a starter motor without enough power. These cars are quite sensitive to weak battery. Have it tested (under load) to see if it works. And to be honest if I were you I might just replace the battery anyway. Not expensive and could avoid other gremlins
Good luck and report back what you find. And if it is an XJ then you might want a moderator to shift the post over to the other board
al_roethlisberger
Mar 1, 2016 06:50 PM
Deeders33
Feb 29, 2016 08:49 PM
