Yet another dumb question from a noob.
Old Nov 2, 2011 | 06:05 PM
CP1's Avatar
CP1
Question Yet another dumb question from a noob.
Windshield squirters.
Mine hardly put any water on the windshield. It only seems to squirt when the blade is almost at rest. Is this normal operation?
Old Nov 2, 2011 | 07:13 PM
jagular's Avatar
Normal operation involves a single deliberate press of the button which should deliver a pre-set amount of fluid unrelated to the length of time you press the button (unlike older systems). Pressing and holding the button will cause more than one cycle of fluid delivery to be delivered in a continuous fashion.
Only if there is a fault or you press the button too briefly will there be insufficient fluid.
If you operate the system normally and too little fluid is delivered then it is faulty.
Old Nov 2, 2011 | 09:48 PM
CP1's Avatar
CP1
By "continuous fashion" do you mean that the water will squirt out as the wiper traverses the windshield or only at the beginning of each wipe cycle?
Old Nov 3, 2011 | 07:58 AM
jagular's Avatar
Only at the commencement of each 6 wipe cycle, if I recall correctly. I seem to think that holding the button down for only a bit longer than necessary has no effect. It seems to operate in cycles. I only need to have more than one cycle during winter which arrives on Friday. I will try it again then and report.
Old Nov 3, 2011 | 10:26 AM
darlo's Avatar
You can have the dealer set it to squirt on the downstroke as well as the upstroke, according to the manual I think (or vice versa - cant recall what is standard). But the squirters are the sorst thing about this car. There are parts of the screen that will never get water.
Old Nov 3, 2011 | 06:10 PM
CP1's Avatar
CP1
... winter which arrives on Friday. ...
You mean November 4th?? Exactly what time warp universe do you reside in?
Old Nov 3, 2011 | 09:27 PM
jagular's Avatar
Western Canada, 50 miles East of the Rockies. Expecting 2 inches of snow tonite.
Old Nov 3, 2011 | 09:29 PM
chekraze's Avatar
it's not meant to spray hard at the windshield causing most of the liquid to hit car behind you.
nice system i think.
Old Nov 4, 2011 | 11:05 AM
darlo's Avatar
He was right - winter arrived here in south east TX this morning - not far off a freeze!
clubairth1
30
Sep 3, 2025 04:38 PM
chatmanx
Sep 11, 2015 07:17 PM
mrplow58
Sep 9, 2015 11:27 AM
deanh
Sep 6, 2015 08:20 PM
