Dash background lights
Old Nov 5, 2012 | 07:13 AM
cygnus x1's Avatar
Unhappy Dash background lights
I've lost all my background dash lights, center console lights, door arm rest lights. Center console selection lights work when I select a certain item (like heater control, seat heaters etc) but the "background" illumination lights do not work. Dimmer does not seem to work or have any affect. Is there a common fuse or connection that controls all the background lights? Makes it hard to drive to work at 5 in the morning!
Old Nov 5, 2012 | 07:36 AM
Doug's Avatar
Looks like fuse #2 (10 amp) in the left side heelboard fuse box.
Near as I can tell the dimmer switch wants supply voltage from the fuse, key "on" voltage from the ignition switch, and a signal/voltage from the light switch. With a test light or meter you could do some basic checks. If it comes down to a wild guess I'd go with a new dimmer switch.
Beyond that I'm no help. Never had to delve into that circuit, sorry. Someone will come along with better info.
Old Nov 8, 2012 | 11:41 PM
Suede's Avatar
I'm correcting a number of issues on a '96 XJ6, and I had the exact problem. There is an "Illumination Control Module" which manages the dash and console lights. It's located just beneath the steering column an looks like this:
Old Nov 8, 2012 | 11:53 PM
Suede's Avatar
I also forgot to mention that Jagbits sells these modules for $112 if you aren't able to source one locally.
JarodL
Mar 7, 2024 01:39 AM
Jpav27
Jul 31, 2022 06:43 AM
jagent
Sep 12, 2015 01:40 AM
mrplow58
Sep 9, 2015 11:27 AM
02jagstype
Sep 4, 2015 08:20 PM
