My XJR headgasket repair.
I jumpered the relays to check the pumps (both ok) then swapped relays around in the trunk. She immediately fired up but pretty lumpy, almost like it was really rich. The lumpiness settled down a bit, then I shut it off to allow the oil to settle so I can check the level and the water too.
No check engine light, so that's good. She might just need fresh gas and a good run.
Went for gas, got a restricted performance message. After hours of fiddling to get my ODBII software working, I got codes P0304 cylinder 4 misfire,
P1316 injector circuit, P0204 cylinder injector circuit malfunction. Question is, which one does this software think is #4?
And oh yeah, I am fixing my sons car at the same time, its sprung a coolant leak.
So, from JTIS:
Any positional references are based upon the following convention: viewing from the driving position, the right-hand cylinder bank is designated bank 1 (A on circuit diagrams) and the left-hand cylinder bank as bank 2 (B on circuit diagrams). The cylinder bores of each bank are numbered 1 to 4, from the front of the vehicle.
Nice! I admit I did the same thing (didn't have a couple injector plugs fully seated.) Once seated it ran excellent, as your seems to be doing now.
Well I'm happy now. She runs smoothly, and drives like a dream. I still have projects/questions, but that's the fun of owning these cars. The airbag light is on, perhaps because I had to remove the passenger airbag to do the carbon fibre mod.
I'd like to figure out a cheap/free way of resetting that. Then a couple dash lights are out, and I want to install bluetooth, program the garage remote, etc, etc.
Before and after:
[IMG]
[/IMG]
[IMG]
[/IMG]
Before and after:
[IMG]
[/IMG][IMG]
[/IMG]
While this project was underway, I sometimes wondered if it would be as quick as I hoped it would be. I am used to the XJ8, and I knew the XJR would be quicker, but how much?
I hoped I wouldn't be disappointed.
Well, no worries there. This thing is fast! At first it wouldn't rev past 5,000 in Sport mode, but after repairing the kickdown switch, and rigging the throttle to open fully, it's all good.
I'm very pleased with the results. 0-60 times.com says it should do 5.1 seconds, and my OBD says 5.7 seconds. Very smooth, very quiet, very fast.
Yes, I am intending to pull the transmission with it. So rad out, all the the hoses/wires off, driveshaft, exhaust and mounts, then out she comes.
It can all be done in place, but the idea of spending all that time bent over the car makes my back ache. Plus as mentioned, the joys of getting older and having less than perfect vision, etc.
I much prefer the thought of having it on an engine stand, where I can see just what I'm doing with out a struggle. the basic shopping list is the entire timing chain kit, upper and lower, head gaskets, octopus hose, S/C hoses, water pump, and any idler pulleys or hoses that look iffy.
Also any repairs/upgrades the supercharger needs. Transmission fluid as well of course.
FS[NorthWest]: XJ8 / XJR 3" Mina Gallery Intake Pipe only (For X308)
xjrjag
Oct 12, 2015 03:16 PM
WTB[SouthEast]: 2000 XJR door seal
moff1959
Sep 26, 2015 05:35 PM
1998, 99, compression, gasket, head, head gasket, jaguar, layer, marks, multi, removal, replacement, timing, xjr, xk8
