Signs of Bad Lower Rear Ball Joints
Old Aug 25, 2011 | 08:12 PM
pezzonovante88's Avatar
Default Signs of Bad Lower Rear Ball Joints
My Jag store notified me that I should replace my lower rear ball-joints. What are some tell-tail signs that they are bad that are noticeable while driving?
Old Aug 26, 2011 | 01:38 AM
Dan R's Avatar
Does the rear have ball joints?
Old Aug 30, 2011 | 08:00 PM
Apparently...
Old Aug 31, 2011 | 11:12 AM
avt007's Avatar
No they don't, at least my 98 doesn't. It has bearings, as seen in my thread reagarding my handling issues. https://www.jaguarforums.com/forum/x...-wiggle-44607/
However, the design may have changed in those three years.
Old Aug 31, 2011 | 06:06 PM
jimlombardi's Avatar
Hi
Your Jag Store have must meant the front end suspension has a bad lower balljoint.
The front suspension has a lower wishbone comprised forged steel front and rear arms bolted together. The rear arm of the lower wishbone has what is called the rear lower balljoint.
In the attached PDF file, the table below the front suspension diagram lists lower balljoint as the Lower Wishbone Ball Joint.
Here are the diagrams of the Front and Rear Suspenison on our XJ models:
https://www.jaguarforums.com/forum/a...components-pdf
There are no ball joints in the Rear Suspension diagram and its table.
The pages in the PDF file were extracted from the JTIS21 Jaguar Shop Repair Manual.
Jim Lombardi
Old Sep 2, 2011 | 07:31 AM
Hi
Here is a forum thread I found on tell-tale signs of bad ball joints:
Wheel Shimmy (wobble, ie vibration) cured - go down to post# 1
https://www.jaguarforums.com/forum/x...ts-5289/page3/
I also found this article on symptoms of worn ball joints:
Symptoms of Worn Ball Joints | eHow.com
Jim Lombardi
Wolfy
May 28, 2024 08:06 AM
PMKimpton
Aug 3, 2019 08:22 PM
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
RaceDiagnostics
Sep 7, 2015 07:28 AM
obwoodie
Sep 3, 2015 07:45 PM
