Turn Signal Silence
Old Oct 3, 2013 | 12:22 PM
Cat Herder's Avatar
Default Turn Signal Silence
The tick-tock sound of the turn signal has become intermittent. The turn signals function normally, just sometimes are silent. Is this an easy fix?
Old Oct 3, 2013 | 07:33 PM
Sean B's Avatar
generally it's the speaker given up the ghost...you can buy from radioshack similar or hack a cheap radio up for one. Or it could be a wiring fault, i.e. solder points on the speaker, I'd be inclined to suspect the former as it went intermittent then died.
You'll need to remove the lower steering wheel shroud to access the speaker and wires, a couple of pozi screws hold it in place.
Hope that helps.
mbergen
Oct 23, 2019 10:26 PM
Daim
Nov 28, 2016 09:28 AM
Richard_gib
Sep 12, 2015 07:08 PM
tonyforman
Sep 10, 2015 07:23 PM
jaguarbill
Sep 5, 2015 11:43 AM
