Changed battery and lost my AUTO up feature on my windows???
Old Jul 27, 2013 | 09:25 PM
GvilleVDP's Avatar
Default Changed battery and lost my AUTO up feature on my windows???
Put new battery in today, and among some other odds things going on I lost my auto up feature on my windows??
can someone help me with what fuse? I do not have a manual..
Old Jul 27, 2013 | 09:30 PM
esloser's Avatar
Probably just has to be retrained. Do the windows still go up/down?
If so, start with the drivers window and push down until the window reaches the bottom. Continue to hold the button down for 3-5 additional seconds. Then, push up until the window reaches the top. Continue to hold for 3-5 additional seconds. Auto up/down should now be trained. Repeat these steps for all other windows.
Old Jul 28, 2013 | 07:40 PM
RDMinor's Avatar
The above works like a charm just don't exceed 4-5 seconds as the windows motors have a thermal fuse to protect against burn-outs due to jammed switches or windows.
Old Oct 5, 2013 | 10:14 AM
srichhaya's Avatar
Default Auto up-down lost in 2010 XF
I realize this thread is in the XJ section, but this was the only hit that matched my problem. I few weeks ago, my 4 year old car battery completely died after sitting in garage for maybe 3-4 days. Anyhow, I got the car jump-started (Took a while using a 4-cylnder car to start an 8-cylinder engine). Mostly everything was fine but I noticed that I could no longer bring up (only) the front windows by a brief pull on the button. The rear windows were fine.
I tried the training process that was recommended above, and after a few tries, managed to get the driver window to behave. However, the passenger side refuses to get trained. IN fact, it now does not move up sometimes by either button (driver door button or passenger door button). It does go up after several tries, and it is getting worse (it started with the first pull not working and then now it is up to 2-3 pulls sometimes before the window will go up)
Any ideas? Appreciate your input.
Old Oct 6, 2013 | 12:01 AM
Muddybear's Avatar
The motor might be going bad. Can you hear the motor trying to raise the window when you pull up on the switch?
philwarner
Oct 4, 2024 01:37 PM
JarodL
Mar 7, 2024 01:39 AM
pnwrs2000
Sep 3, 2015 11:55 AM
XFR_Gold
Sep 2, 2015 12:24 PM
XJsc-guy
Sep 2, 2015 11:43 AM
