XJ ( X351 ) 2009 - 2019
'14 xj v6 fuel rail pressure sensor location
Old Mar 4, 2026 | 01:43 PM
High123bid's Avatar
Default '14 xj v6 fuel rail pressure sensor location
Hi,
Got a P0191. Where is the fuel rail pressure sensor located, please? I am used the the luxury of said being the first you see when you open a Mercedes hood.
Regards, Bo
Old Mar 4, 2026 | 02:17 PM
Jaaag_drivah's Avatar
It's on the left side of the engine near the back of the valve cover on the fuel rail. Significant disassembly is needed to access this, including unplugging the ECU harness, removing the wiper arms and all the fiberglass mat and windshield lower cowling. Do not replace with an aftermarket part- OEM only or it will cause random limp mode issues.
Old Mar 4, 2026 | 02:35 PM
High123bid's Avatar
Thanks. So left Driver's side. Bummer. Thanks, Bo
Old Mar 5, 2026 | 08:11 AM
Nope, it's on the passenger's side (in the US) fuel rail. Driver's right.
Old Mar 5, 2026 | 08:18 AM
High123bid's Avatar
Thanks. I saw that. I only found a video for Range Rover/Land Rover. It seems to have more space. I hope I can get a socket in there. 1-1/16th apparently.
Natejmoney
Feb 7, 2026 01:34 PM
Wingrider
17
Apr 10, 2025 12:25 PM
Pancho Deez
Aug 14, 2023 06:37 PM
EnglishTerry
Jul 6, 2023 11:44 AM
BradsJag
Nov 6, 2018 09:04 PM
