XJ ( X351 ) 2009 - 2019
2004 xjr air suspension down
Old Nov 3, 2015 | 05:51 PM
maxrush's Avatar
Default 2004 xjr air suspension down
Hi, New to the forum, need some advice, driving the other day, in the rain, air suspension fault showed up, front end dropped. Drove the car home, did some checking, no leaks,switched out relay, nothing.
Compressor does not come on, although if you jump the pins on the relay it runs and delivers pressure to the solinoid valve, but does not distribute to any lines.
Checked as much as I can, gathering info from your previous posts, need some help.
CAr has 93,000 miles on it and has been perfect up to this point. HHHeeelp
Old Nov 3, 2015 | 07:51 PM
edobernig's Avatar
Default Posted in wrong forum model area
Max re-post this in Jaguar Models (Modern) XJ 350-358 2003-2009. Air suspension issues are very common. Please check for posts in that section.
Old Nov 4, 2015 | 07:05 AM
maxrush's Avatar
Thanks, I will.
mhamilton
Jul 29, 2016 12:22 PM
nlt624
Oct 20, 2015 11:48 AM
SRL1990
Oct 19, 2015 06:48 PM
LnrB
Oct 18, 2015 10:53 PM
kevinl
Oct 18, 2015 11:45 AM
