XJ ( X351 ) 2009 - 2019
2005 Jaguar XJ8 Reduced performance and erratic shifting
Old Dec 18, 2021 | 12:26 AM
Fbalcazar's Avatar
Question 2005 Jaguar XJ8 Reduced performance and erratic shifting
Hello everybody.
I have a 2005 XJ8 working just perfect until I just start the car and the transmission shifting erratic and I have the Reduced performance light
How I can correct this problem?
Old Dec 18, 2021 | 11:16 AM
clubairth1's Avatar
Community Influencer
You will get better answers if you post in the section for your car. This is for the later 2009-2019 XJ's.
Old Dec 18, 2021 | 11:35 AM
NBCat's Avatar
@Fbalcazar, two things to check before going any further with a diagnosis:
  1. Battery voltage across the terminals when checked with a voltmeter. There should be a minimum of 12.6 volts available for all modules to communicate along the CAN-BUS.
  2. Fluid level in the gearbox. If it hasn't been serviced, it should have a fluid change and pan/filter replacement every 100,000 km/62,000 miles or five years.
Are there any DTCs stored in the system? If so, post them in the X350/358 forum.
thomash85715
Jan 13, 2019 11:55 AM
Markmont
Jul 4, 2013 10:43 AM
Staz203
Apr 20, 2011 04:28 PM
bkrpdx
Oct 15, 2009 01:24 PM
