XJ ( X351 ) 2009 - 2019
2008 Vanden Plas
Old Dec 24, 2013 | 08:18 PM
joeglow42's Avatar
Default 2008 Vanden Plas
OK..what should I be looking at at 60,000 miles? Belts, hoses etc i know. Any big items that may be a problem. Thanks
Old Dec 25, 2013 | 01:41 PM
Fraser Mitchell's Avatar
Sorry to have to tell you, Joeglow, but you've posted in the wrong forum. Try posting in the X350 forum; this one is for the current, (and very "avant garde" style), current XJ saloon, model series X351 from 2009. Not all cars are affected, mind you.
I assume you know these cars are made of aluminium, not steel.
As to your question, 60k probably means you'll need a new air suspension compressor fairly soon if not already replaced.
Check for "filiform" corrosion at :
- leading edge of trunk lid
- trailing edge of trunk lid above the "Jaguar" escutcheon
- near D-post at lower screen seal
- door corners.
This is an unsightly but fairly harmless, and peculiar to aluminium, corrosion mode. However it doesn't look good and can be expensive to remedy if you take the car to a paint shop. Of course much depends on the shop, as those used to painting aluminium will know what to do.
Basics such as evidence of servicing and care by the previous owner is also essential. At 60k these cars are still young, with probably another 100k miles at least in front of them.
JungleJonny
Oct 5, 2015 03:52 PM
37driver
Oct 4, 2015 05:58 PM
millertic
Sep 30, 2015 08:11 PM
Col. Sandurz
Sep 28, 2015 07:29 PM
