2011 jaguar xjl 5.0l
Just had the rear coolant cross over tube or whatever you call it crack and leak coolant I’m repairing the car and was wondering what psi should I pressure test the cooling system that way I can make sure that that was the only part leaking thanks for any help
While you are in there replacing this part you should consider upgrading/renewing the other problematic cooling system parts and tubes with this kit: https://euro-amp.com/products/jaguar...ipping-returns
Assuming you have the SC not NA engine that is.
Jamel Smith
General Tech Help
Sep 23, 2018 05:12 PM
