XJ ( X351 ) 2009 - 2019
2011 XJ Supercharged
Old Mar 11, 2021 | 12:11 AM
Nicholas Fernandez's Avatar
Default 2011 XJ Supercharged
I've been thinking about buying a 2011 Jaguar XJ Supercharged (110,000 miles) that's for sale near me. Are there any common issues I would need to be aware of prior to purchasing it? Thanks.
Old Mar 11, 2021 | 07:43 AM
ChaosphereIX's Avatar
coolant system and make sure it has full service history - 2011 was an early year you want to make sure there were repairs done to fix things
Old Mar 11, 2021 | 08:39 AM
XJsss's Avatar
Water pump, coolant plastic pipes, timing chain guides and tensioners, and supercharger snout coupler are what comes to mind. BTW all of those have been done on my XJ and may have been done on yours considering your mileage.
Old Mar 11, 2021 | 10:10 AM
clubairth1's Avatar
Community Influencer
All good advice! Especially the list XJsss posted. It will save you a LOT of trouble!
Any chance you can get the maintenance records of what's been done?
Old Mar 12, 2021 | 03:12 PM
Nedoerr's Avatar
Agreed with xjsss on timing chain tensioners, cooling system, supercharger snout. Also check for codes with a code scanner and make sure codes weren’t recently reset.
There are also several wear and tear items due around this time too:
suspension bushings, transmission and engine mounts, brake rotors, etc. If these haven’t been done recently they can get costly.
Other common quirks may include sunroof shades not working, sunroof track rusting, buzzing/rattling from behind door, speaker rattling, check that ventilated seats work (some have cracked ducting), slow touchscreen (can update to 2012 screen), and sticky buttons.
Old Mar 23, 2021 | 10:02 PM
4.2xfsv8's Avatar
have you had any issues with the waterpump after? I was looking at buying a 2015 xjr swb.
Old Mar 23, 2021 | 10:05 PM
4.2xfsv8's Avatar
Have you had any issues after the latest waterpump? I was looking at purchasing a 2015 xjr as an upgrade from my 2009 xf supercharged.
d33
Sep 26, 2015 11:02 AM
chuckh007
Apr 16, 2014 11:18 PM
Pa.Bill
Dec 22, 2013 07:32 AM
AutoMedia
Dec 15, 2010 03:06 PM
hunterjah
Sep 14, 2010 05:24 AM
