XJ ( X351 ) 2009 - 2019
2014 Xjluxury rear driver door not looking
Old Sep 10, 2021 | 05:06 AM
Abdulrahmantab's Avatar
Default 2014 Xjluxury rear driver door not looking
Hello everyone I have a question, unfortunately I had an accident which I had to replace the rear driver door skin only!
The window glass & motor, shade and the lock were working before replacing the door shell
after the door is replaced my window, privacy shade and door lock stopped working but when I press the lock button it looks all other doors so there is electric power there!
But when I look the car from out side it doesn’t lock that specific door or fold the mirror in or flash the turn signal then after 5-10 seconds it beeb once.
Can anyone help?
Old Sep 10, 2021 | 07:54 AM
Stuart S's Avatar
Take it back to the shop that did the repairs. You paid them to fix it and while doing so they broke something else. They should fix it or reimburse you for paying a Jaguar dealer to do so. If they refuse, talk to a lawyer.
Old Sep 11, 2021 | 10:01 AM
Baltobernie's Avatar
I too cannot electrically unlock the LR door. Like your situation, it will lock, but must be manually unlocked with the inside handle.
While I was having my sunroof rattle fixed, I mentioned this to the (highly experienced Jaguar) mechanic. I thought it would be a minor repair; maybe a defective solenoid. Nope, it requires replacing a module costing several hundred dollars. I suspect you will ultimately face this same solution. Like Stuart says, return to the repair shop.
Spikepaga
May 7, 2019 09:06 PM
gibbon
Nov 20, 2017 09:51 PM
razorboy
Oct 5, 2017 06:15 PM
graham11
Oct 19, 2016 12:31 PM
mikebaker3
Jan 19, 2015 06:37 PM
