XJ ( X351 ) 2009 - 2019
2016 XJ L
Old May 28, 2021 | 02:39 PM
Na5h's Avatar
Question 2016 XJ L
Hi! Looking at buying a 2016 XJ L, V-8 sc. Last Jag I had was a 2011 XJ8 L. Asking the brain trust here of what I should look for that are problematic in the last variants of the XJ? How about the engine: is it pretty durable and reliable? Suspension: is it pneumatic like on the 2011 XJ8? Any info on other areas would be appreciated.
TIA,
Nash.
Old May 28, 2021 | 02:52 PM
ChaosphereIX's Avatar
2016 is a fairly decent year, should have most if not all of the improvements to the problem areas already taken care of (cooling pipes, timing components, sunroof/sunblind rattles, rear only air suspension, etc.) Usual caution with any old Jag, make sure the maintenance was kept up or BETTER, more frequent these things change their oil, the better.
Old May 28, 2021 | 04:45 PM
12306Jaguar's Avatar
As you'd be going from n/a v8 to s/c v8,
Anxious to hear others' opinions on the feel differences.
Sound and grunt differences should be quite noticeable?
2016 s/c v8 would be a fantastic but are quite rare.
Either way, buy a new battery right away if current one is over 30 months old: saves a lot of spurious error headaches.
Old May 28, 2021 | 04:53 PM
I drive both every day, you feel the difference between the two for sure. If you can go S/C V8, do it. You will regret it if you do not.
Johncy2000
Mar 13, 2026 08:58 AM
raptor
General Tech Help
Dec 16, 2020 03:20 PM
lobercio
Sep 13, 2017 01:58 AM
KarlC
Sep 25, 2016 05:57 PM
eddalejr
Feb 16, 2016 07:26 AM
