XJ ( X351 ) 2009 - 2019
AC squeal when coasting and sometimes in low rpm situations
Old Jun 29, 2022 | 04:16 PM
NielsL's Avatar
Default AC squeal when coasting and sometimes in low rpm situations
The noise goes away with AC off. When accelerating the noise also goes away. Makes me think its the drive belt. Ideas how to check this at home?
Old Jun 29, 2022 | 04:48 PM
George05's Avatar
sounds like a bearing is gone in the AC unit or as we say use it or lose it . george
Old Jul 1, 2022 | 01:49 PM
NielsL's Avatar
Default Belt tension feels pretty low...
Today I took a closer look under the hood. The drive belt for the compressor feels a bit sloppy. I can deflect the belt about 1/2 inch by pressing with just two fingers. I would expect nearly no deflection at all, but I might be wrong. There is not much room to use a belt tension gage. I wonder how involved it is to tighten up the belt. Or to change it altogether.
Old Jul 1, 2022 | 02:59 PM
12jagmark's Avatar
Originally Posted by NielsL
... I wonder how involved it is to tighten up the belt. Or to change it altogether.
Not too difficult - takes nothing more than replacing the belt tensioner.
That is unless George said, and an idler pulley bearing has failed and is causing the slack.
...you can't manually tighten it. The tensioner keeps it as it should be.
And yes, it would be a good idea to replace the belt at the same time if it's getting old.
chillyp
Sep 9, 2021 06:52 AM
RA110623
Jun 27, 2020 09:51 AM
Reklaw1973
Jun 3, 2019 10:55 AM
Kikzin
Jul 15, 2018 09:09 AM
Walter1982
Apr 29, 2009 10:48 AM
