Aftermarket water pump
Subscribe
Jun 5, 2022 | 12:23 PM
Anybody use an aftermarket water pump say a
BECK/ARNLEY 131-2464 Water Pump
Reply 0
Jun 5, 2022 | 12:35 PM
Check out the X150 Forum. I believe at least one thread shows something about getting the Beck?Arnley pump.
Reply 0
Jun 5, 2022 | 05:35 PM
I've used Beck Arnley parts and coolant, but from what I've seen, they don't produce products, but they re-label/repackage from other suppliers. And from what I've seen, the parts they sell are upper-level suppliers.
I'd trust a Beck Arnley when I choose something other than JLR for things that don't get replaced often, but for the pump, I think I'll be going with genuine JLR although the Beck Arnley is $84 to the JLR $250. Not because I trust the JLR any more than a Gates, Uro or Beck Arnley, but simple personal preference.
I put a GMB pump in my Range Rover with the same engine, and it's working fine, but once I found the GMB is made in China I wish I'd gone with the Italian-made JLR pump.
Reply 0
Jun 6, 2022 | 11:34 AM
I've been running that Beck Arnely pump now for about 3 years and 18k miles with no issues.
Reply 1
Jun 7, 2022 | 06:47 AM
[QUOTE=XJ8JR;2532280]I've been running that Beck Arnely pump now for about 3 years and 18k miles with no issues.[/QUOTE
Great!!!
Reply 0
Aug 29, 2022 | 10:57 AM
UPDATE. My Beck Arnely pump just started leaking
Reply 0
Aug 29, 2022 | 01:15 PM
Quote: UPDATE. My Beck Arnely pump just started leaking
You Jinxed it!!!!
Murphy's law strikes again.
Just for curiosity about specifics, where is the pump leaking from?
Reply 0
Aug 29, 2022 | 03:38 PM
Ha. Murphy's Law is quite prevalent when working on cars or watch movements. And my cat's name is Murphy.
I haven't yanked it out yet but it looks like its just leaking out from the bottom rear where the unit meets the engine block, almost like the gasket failed.
Reply 0
Aug 29, 2022 | 06:30 PM
Quote: Ha. ... almost like the gasket failed.
Nothing on the pump to fail back there, so probably a gasket. Or the oil cooler seal.
Hopefully nothing much. One good thing is that it's easy to get to, with an electric radiator fan, less in the way to get to it.
Reply 0
Aug 30, 2022 | 02:51 PM
I pulled the water pump yesterday but unfortunately couldn't tell exactly where the leak occurred due to all the mess it made. I hate doing anything involving coolant. Its impossible for it not to get everywhere.
Reply 0
Aug 31, 2022 | 07:59 AM
Quote: Nothing on the pump to fail back there, so probably a gasket. Or the oil cooler seal.
Our 5.0l does not have the SC so very easy to get to.
Reply 0
Sep 5, 2022 | 08:51 AM
Be sure and replace the plastic water tube behind the pump with the nice aftermarket Aluminum version.
It's a quality upgrade.
Reply 1
Sep 6, 2022 | 01:28 AM
Has someone a manual to change the water pump?
Reply 0
Subscribe
Currently Active Users (1)
