XJ ( X351 ) 2009 - 2019
Air Compressor too hot? Suspension Fault
Old Oct 28, 2017 | 11:07 AM
sutherland's Avatar
Default Air Compressor too hot? Suspension Fault
My XJ is permanently reporting a suspension fault with the amber warning. The left side of the car is around one finger lower than the right, but the only obvious problem that I can detect is that the round part with the electrical connection on the top of the compressor is hot to touch, even after the car has just been started.
Is it normally hot? Is there anything I should check inside the compressor? There are two screws which may be removed on that connection. If I replace the compressor, is that a DIY job or do I require a specialist?
ANy advice or compressor experiences would be appreciated. Thank you.
Old Nov 4, 2017 | 04:45 AM
sutherland's Avatar
Well it seems the compressor is at fault -- I have a new one on the way.
Another consequence of the failed compressor is that that forward alert also develops a fault as it gets the wrong signals from the suspension system.
Old Nov 6, 2017 | 06:24 AM
dragonalfa's Avatar
I had same problem on mine, it was replaced under the warranty luckily.
Old Nov 6, 2017 | 04:16 PM
sutherland's Avatar
Sadly, I've no warranty.
I've read that on the previous model (X350) Jaguar recommended replacing a relay at the same time as the compressor. Does anyone know if that also applies to the X351 or did they solve that problem?
Old Nov 6, 2017 | 04:46 PM
rhomanski's Avatar
It's not really a problem as it is normal operation. Any relay that transfers high power will get arcing on the contacts and will eventually stick. That will burn up your new compressor. It's always a good idea to replace any associated relays. Ten bucks for a relay or another compressor in a couple days.
GM recommended replacing the power relay and the burn-off relay everytime you change the MAF sensor on the Corvette. I didn't the first time. I did after that, everytime.
