XJ ( X351 ) 2009 - 2019
Aluminum Replacement for OEM Plastic Coolant Pipes
Old Feb 15, 2024 | 07:03 PM
  #161
dmchao's Avatar
Default Re/
Yep! It’s actually in quite a few internal ISO automotive standards that you MUST use them.
I used to design coolant systems for the highest volume truck manufacturer in North America. The water pump iterations on the XJ are a sham. The coolant failure modes are despicable.
but I cannot discount that they probably meet market expectations and allowed Jaguar to compete in the class they are in for the time they were launched. Cost, cost, cost
Old Feb 15, 2024 | 09:52 PM
  #162
QP7's Avatar
QP7
Well, I stand corrected then, no problem. So are we saying then that spring clamps are the best we can manage? What happens when with age the spring / resistance gives out? Not trying to be clever just would like to know... Put it this way if you needed your X351 coolant system to last 250,000 miles what would you do?
Old Feb 15, 2024 | 10:13 PM
  #163
dmchao's Avatar
Default Parts
Preventative maintenance is the best cure. Clamps aren’t really a high impact failure mode in a cooling system. The coolant itself aging is higher risk than a clamp.
Old Feb 16, 2024 | 12:19 PM
  #164
clubairth1's Avatar
Community Influencer
Yes I had to learn about clamps to. As I had been replacing the very good factory constant tension spring clamps (This is the key-Constant Tension!) with the old Jubilee screw clamps.
Why? Because I was always told they were better! But the screw clamps actually create failure points because of the large stress concentrations directly under the screw mechanism.
Now I do struggle with the constant tension clamps compared to the screw type but after getting a cable clamp hose pliers they are somewhat easier to use.
bfx308
May 15, 2022 08:18 AM
jcb-memphis
Jan 12, 2022 02:21 AM
VicVegas84
Sep 28, 2021 09:59 PM
VicVegas84
Jun 28, 2021 07:37 PM
Luis Antezana
Jun 17, 2020 06:20 PM
