XJ ( X351 ) 2009 - 2019
Amplifier replacment
Old Aug 25, 2020 | 11:10 AM
Veon's Avatar
Default Amplifier replacment
Hi, I have a 2012 xjl with bowers and wilkins sound system. I noticed that the subwoofers on the rear deck are not working or working 10%. I read on the forum that this is probably bad amplifier problem. Can someone tell me what amplifier code/part number I should be looking for to replace mine? I'm thinking I shouldn't be looking for the same one cause I don't want to have same problem again. Or did anyone try to fix amplifer itself?
Amp that's in car now
Old Aug 25, 2020 | 04:41 PM
Thermo's Avatar
Veteran: Navy
Veon, you want to look up the BJ32-19C164-BF. Of interest is the 19C164 number. That is the part number of the amp. The BF is a version number. You can try getting a bit of a newer number, but the farther you get away, the more likely you are to have issues. The BJ32 is just a reference to what car this was originally designated to go in.
Old Aug 26, 2020 | 04:43 PM
Veon's Avatar
Hey Thermo, thanks for quick answer. I already have BJ32-19C164-BF original amp in the car, as you can see on the photo, maybe I understood it wrong but isn't it better to get a newer model amp so I have less chances of having same problem again? And if so how do I know by part number which one is newer or which one will fit my sound sytem plug and play?
Old Aug 26, 2020 | 04:52 PM
Thermo's Avatar
Veteran: Navy
Veon, a newer version (ie, something with an ending higher than "BF" like BG or BH, etc) will be a newer unit. But, like I mentioned, you get too far ahead and you can potentially run into compatability issues. Where the line is, I am not sure. You should be good with any system that is still the B&W, you get into the other system and odds are you will have issues.
Mongoose
Aug 10, 2018 10:47 AM
latejaguar
May 11, 2018 07:48 PM
Baziran
F-Pace (X761) / C-X17
Sep 14, 2017 04:14 AM
Jont
Jul 16, 2017 05:45 PM
rsd911
Apr 25, 2016 05:19 PM
